Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 14 4:15 am)
It searches all the drives and volumes on the system for Poser installation. If you have more than one, it gives you a choice of which one to install to. I have two 80 gig drives, and 4 Poser installations, so I always stop it and locate myself. If you wait like you mentioned, it will have already found one installation and is still checking the rest of the drives.
I handle it differently... I don't install anything till I'm ready to work on something. By then, I have 10-15 products from DAZ waiting. The first install takes a while, as "tha dodger" says. But after than, because it's cached or what, each install finds the Poser folder almost instantaneously. So, I only have one long wait out of 10-15 products installed (LOL).
Damn those 80 gig hard drives and custom Poser installs. :) I usually do a quick quit too. But your right. Don't quit right away. Wait a few seconds.
-Anton, creator of
ApolloMaximus: 32,000+ downloads
since 3-13-07
"Conviction without truth is denial; Denial in the
face of truth is concealment."
If DAZ is taking suggestions, I have one... You know how when you install a driver in Windows it gives the options of 'Search for the location of the driver' and 'Specify the location of a driver' and the search box has a dropdown menu of places to search? Something like that, where you have a dialogue at the beginning that says: Where should I install the DAZ Product you have purchased?
You don't need a speedup if you never wait. Heh I never install directly into Poser anyway, so cancelling, then pointing to my 'Poser Install' directory is quick and easy. Even for updaters that must be installed directly into Poser I cancel and show it where Poser is. I still HATE exe's though. I can't peek into the dern things.
I've thought about 4 or more Poser installs-- one for Fantasy, one for urban grit, one for fashion, One for sci-fi. I wait about 15 20 seconds and click cancel-- it usually has found both of my installs by then-- but not the cannibalised one on the auxilliary drive. I also like to install a lot at once, and I'm on XP, so for the next one I can cancel right away and it has the one I want to install to right in the window waiting. Emily
Making XP look like Windows is dead easy. Right click on the background, select Properties, select the Appearance tab, then select Windows Classic Style from the drop down. That's how I have mine set. Rainy Day colour scheme, if you're interested. :)
Spit: Do you mean both are unstable, as the prefix 'Windows ' on the OS name implies, or that both are stable? See, to me, 'stable' means Slackware Linux with the kernel custom compiled for the machine it's running on, with the concept of rebooting limited to hardware changes and kernel upgrades. I've heard the difference between the primary OSes describes as thus: UNIX/Linux you reboot once every six months when you buy mor RAM, Macintosh you reboot once a week when the OS forgets it's supposed to exist, Windows you reboot three times a day because you have no choice.
As a small note: while Linux is generally 'stable' in the non-relative sense of the term, even the hardiest OSes ever designed can crash when you set your apache MaxClients too high while running mod_perl Apache with MySQL... as I have recently discovered. There exists a point at which even the most perfect OS available can find itself screaming under too high a load and end up locking up from using all its CPU to swap because the real memory ran out three days ago B^)
I cancel immediately and tell it where to point too. I REALLY wish DAZ would offer a zip option though. Especially with offerings that have multiple "articles." With zip files I often choose to just install just one piece of the package. A prop for example rather than 2 vicki textrues and all the associated pz2s, vicki clothing objects, cr2s, and textures, hair..., etc. It keeps the librarie size down and makes uninstalling when you're done easier. Please DAZ. How 'bout a zip option?
Well, um, you never tried the Amiga then. I had a runaway program that was eating all the ram. When the ram filled up my Amiga popped up a message telling me ram was full. So I killed the process and cleared stuff out of my ram disk and went merrily on my way. Back to XP. I rebooted yesterday because the latest MS security update required it. Other than that I haven't had to reboot since I don't even remember.
Pablo: You can tell it not to on install or afterwards in preferences. Spit: yup, I can make X-windows do that too, but I can't see what's going on on the console of my Linux PC. It's in a co-location facility in Portland and hasn't got a monitor -- it's a server B^) -- the only way I can run X on it is remotely from here using WinaXe and, well, that means that I daren't have it up all the time. No reboot since unknown? Well, that is impressive...
I generally don't bother aborting the initial drive search, but then I'm reasonably patient and my system doesn't take much time for the search. I tend to buy multiple things when I'm on a DAZ shopping spree, and all the installs after the first one bring up all the poser installations the initial search found. This is on XP by the way. I make my own zip files from DAZ stuff by installing to a "fake" poser directory. It's simply a folder with a copy of Poser.exe in it, anything the installer adds can be simply highlighted and compressed to create an explorable archive of the product.
For those who asked why I use 4 different installations, it is simple. I'm a developper. I need to have each Poser version isolated to test my products accordingly. So I have 4 installs. Poser Pro Pack for developping. This has a mess in Runtime from all the folders created during production. This is where I also install stuff I buy or get from free areas to test prior to droping it on my clea Runtimes. Poser 4.03 For compatability testing. Poser Pro Pack for my actual Poser enjoyment. Poser 5 for compatability testing. This keeps my work organized and easy to manage since I know where the messes are.
I'm a "clean freak"! In each of my sole installation of Poser 5, Vue and Brcye 4,I have only the products installed I'm planning to use....when I'm done with them, I move them to a CD Rom. I also store new products I've purchased on CD's until I plan to use them. I have lots of CD Roms and very well organized PC :)
Since I generally install more than one product at a time, I also find that after the first DAZ install, it goes a lot faster (running XP Pro.....a totally stable OS that you can run for a month without rebooting! And more useable than my Linux Mandrake, with its limited software options)
Well, not the totally impatient, but still... DAZ's installer looks for where you have Poser installed when you run it. This, for smoe reason, can take a long time. I get the impression that it looks in numerous places for it before guessing at the location. Here's what I've found: If you wait for it to find it (at least on my machine) you'll fall asleep before it succeeds. If you cancel it, you'll have to browse to your Poser 4 install directory. HOWEVER If you count slowly to 15 and THEN cancel it, it will have the right directory pre-filled. I'm not sure what it's doing after that point shrug. Anyway, thought I'd share this tip.
