Fri, Nov 22, 5:17 PM CST
Subject: Parenting Qs for MgVest and Curly Hair
cainbrogan ( ) posted Sat, 08 February 2003 at 5:55 AM ยท edited Fri, 22 November 2024 at 12:31 PM
When I try to parent Awful Soul's MgVest it jumps onto the small of Stephanie's back. I'm trying to parent the body of the vest to the chest, and am thinking that I might be using the wrong MgVest part. Should I be Parenting a different group? I also have had a recent problem with DAZ's Curly Bendy Hair. This may have been a glitch, but I've also parented it from its Body, but I got a really wierd texture the last time I loaded this scene... Thanks ahead of time! = )
compiler ( ) posted Sat, 08 February 2003 at 6:52 AM
I usually stick to conforming OR parenting hair and clothes to the figure. Doing both at the same time can get some unexpected results... If you must parent clothes to figure, I'd suggest parenting them on a part by part basis (the cloth chest to the figure chest for instance). this will work well if the cloth is designed for the figure you use, but you'll still have problems when parenting clothes for Posette to Vicky (something to do with center points, I guess). Compiler
cainbrogan ( ) posted Sat, 08 February 2003 at 11:17 AM
I tried parenting the front left cloth to the chest and the whole top fliped behind Stephanie again! = )
compiler ( ) posted Sat, 08 February 2003 at 11:35 AM
Did you try parenting the chest of the cloth to the chest of your figure ? Or parenting the body of the cloth to the body of your figure ? Or, if it has a hip, the cloth's hip to Stephy's hip ? I also remember that this cloth is made for Vicky, and that Stephanie is derived from Michael mesh. This could explain that. Good luck. Compiler
