Attached Link: http://www.poserpros.com/forums/viewtopic.php?t=4664&highlight=blood+101
There's a tutorial at Poser Pros by Sinister called Tutorial Blood 101 that you might find helpful, especially for what you're trying to do. Link above.Too many rivulets of blood as well- blood is thick and has cohesion so it tends to stick together. Maybe only one or two branches as it runs down the arm. Also, it'll be rounded at the ends where the drops pool up, not spiky, and won't thin out so much- nearly as wide at the bottom of the stream as at the middle. If you can actually bump-map or distortion-map the drops at the end, that'll add even more realism.
Depends upon whether you intend the blood to be coming out of an artery or a vein. Blood tends to spurt out of arteries and drip out of veins. You will want some blood drops as well as being smeared across the skin. The surface tension of blood keeps the shape uniform. So the drop is spherical not tear-drop shaped. The easiest way to deal with the blood smears is postwoek. When you smear the blood across the skin do it in several layers with transparencies so it isn't all the same color. That way the wound still looks like its bleeding while some of the red blood cells would appear to have dried on the skin.
blood drips and forms beads at the bottom of the drip and it drips down, not across. Heh, no pun intended. Look online for some fake blood recipes and mix some up and out it in the right places. Observe what it does. Or, if yu don't want to mix up fake blood and you're willing to suffer for your art... there's always the gothier approach.
hmm...for smeared & painted blood, a good photoshop layer or three should do the trick. If you have photo shop, use the polygon select on a new layer over the area you want the blood...fill it w/ a crimson color...deselect your polygon...use the smear tool & smear the blood how you like it...then use the burn tool to created the dried or coagulated blood effect. then you can use the dodge tool for lighter, less stained areas. Oila! at least...that's what I'd do. Evo
I don't get it either. Where's that blood??!
Hmm.. if the orange tint of the eyes is supposed to be blood... sorry, it doesn't look like blood to me.
Ah :o} It was JUST outside the wiewable area of my screen... Still I think it needs some glint or bevel or whatever. Looks more like a tattoo to me :o) Would make a cool tattoo btw...
Well... I tried to get a blood effect with eye candy... I painted just the way you did, but it was drip by drip.. then I used the layer effect to emboss it.. them I used eye candy chrome effect (crimson) .. then.. I smeared with the brishes and I think I almost got there... hope it helps a bit hugs ILona
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=333142&Start=1&Artist=RaysOfLight&ByArtist=Yes
how could i make the blood in this look a bit more realistic?
