Tue, Dec 24, 11:34 PM CST
Subject: Poser 4PP Right hand menu listing problem
Watcher2K ( ) posted Wed, 12 February 2003 at 8:30 PM ยท edited Tue, 24 December 2024 at 11:32 PM
Hi again all, I am not sure if there is a work around for this problem or if it just a problem I am experiencing but any info on how to correct it would be good. My problem is when I choose the Character listing I can pretty much see the name of the all the files I have as the width of the column is around 12 characters, however when I choose the Poses category the display panel only shows about 5 or 6 characters making it very hard to try and figure out what the file is as I have customized the name of my files to things like V2-XXX and M2-XXX (XXX being the name of the clothing or model etc. Does anyone know how I can increase the width of this panel so I can see more of the library names. Thanks in advance for any assistance with this. :)
rogergordian ( ) posted Wed, 12 February 2003 at 9:13 PM
Attached Link: http://www.curiouslabs.com/
You're running into two possible problems: 1.) You have too many items installed (I believe about 250 in a given category is the limit). The best answer for that problem is PBooost. It costs about $20 and I think you can find it in the Renderosity Marketplace. 2.) Poser Pro Pack had a problem with long filenames. That fix was handled by the latest Service Pack. I've provided the link to the Curious Labs site for your convenience in case you need further research.
queri ( ) posted Thu, 13 February 2003 at 12:47 PM
You cannot increase the width of the column , your best bets are to see if you can combine a few folders right now so tht you can get under 255 which I believe is the max. Then do take a look into PBoost, it allows you to move folders you are not using out of your libraries and keep them safe, and then move them back in when you need them. We've all run into this problem of Poser 4 and PP not allowing embedded folders in the libraries. Emily
