Mon, Nov 25, 3:36 PM CST
Subject: Quick newbie question about Victoria 2
Talos ( ) posted Mon, 17 February 2003 at 2:44 PM · edited Mon, 25 November 2024 at 3:34 PM
I've had very little time for Poser for the past 2 years, so I was wondering why when I save a Victoria 2 character, Poser doesn't save my morph dial settings. I open up my file later, and she shows up looking like default settings. What did I do wrong?
Nance ( ) posted Mon, 17 February 2003 at 3:18 PM
I'll give it a shot... If a .cr2, there is no way NOT to save the current settings. If a .pz3, could you be looking at the wrong frame? The only other thing that comes to mind is Crosstalk effects on full body MTs. Are you loading this figure into a scene with a similar figure without a null figure?
Hawkfyr ( ) posted Mon, 17 February 2003 at 4:02 PM
I think you need to create a full body morph. This should give you a new dial that can use to morph the body changes all at once. I could be wrong though. good luck. Tom
“The fact that no one understands you…Doesn’t make you an artist.”
evilded777 ( ) posted Mon, 17 February 2003 at 5:26 PM
Indeed... how are you saving? I suggest added your charcter to your library, as that saves all morph information. As an added safety... Edit > Memorize > figure before you add the character to the library. But even if you are saving out to a .pz3 files, all information should be saved... very strange reaction you have there e.d.
Talos ( ) posted Mon, 17 February 2003 at 6:25 PM
Thanks everybody, and I will try every suggestion. This is a strange mystery. Still investigating. It was a fairly simple character with nothing else in the scene but a box used as a wall, and some Maya studio hair. I did upgrade to Windows XP last month, and had to reinstall Poser. No real problems with that yet. I have tried spawning a morph target for any faces I create as one sneaky way of saving the face. I did nothing special with the body. That seemed to have fixed it for today, unless the problem went away by itself. I lost every character I created on Saturday.
