Fri, Jan 10, 12:50 AM CST
Subject: Orc eye transmap problem
pack ( ) posted Mon, 17 February 2003 at 4:52 PM ยท edited Thu, 09 January 2025 at 5:03 PM
I can't ever see the Orc's iris, nor eyewhite maps. I copied setting for working Mike2 setups- but nothing. Any advise??
n0s4ra2 ( ) posted Mon, 17 February 2003 at 6:40 PM
Which orc?
I have one in free stuff and daz has some, I was just wondering if it was mine.
If so those were my first textures .
I could have over looked something.
Ghostofmacbeth ( ) posted Mon, 17 February 2003 at 10:27 PM
The eyeball material is probably the culprit. It should be turned up so it has a min and max of 100 with a highlight color of a medium or dark grey with the highlight set to 70 or so.
pack ( ) posted Tue, 18 February 2003 at 1:22 AM
Yes yours. I worked around by importing an Orc MT onto another working figure. Even comparing settings- i could not figure it out. Also 3dsMax obj's not working well at all, unless I use PPP export pz3 import to Max thnx Pack
n0s4ra2 ( ) posted Tue, 18 February 2003 at 1:37 AM
Is the problem with the iris and eye white maps not working only in max or does it do it in poser?
I dont use max but, what you are saying is other characters import in to max, but the orc wont?
Strange.
You may want to ask on the max forum if this is the case.
Sorry for your trouble
pack ( ) posted Wed, 19 February 2003 at 12:56 PM
The problem is in Poser Pro. Not that there aren't also Max problems....... The eyewhite matireal - I can change its color- but never see the map- as if the UV changed.
RawArt ( ) posted Thu, 20 February 2003 at 5:56 AM
Hmmm.....maybe if you post a picture of what is happening, we could figure it out more easy. I have this character, and the eyes seem to work fine (as in the picture)...or maybe I am misunderstanding the question. Rawnrr
