Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 3:31 pm)
I think Tailor is pretty limited in as far as the object must be made for the figure. I've tried to reduce breast sizes for a number of Victoria clothing items to fit one of my V2 characters and have had little luck with the program. Kind of sorry I picked the thing up. I've been thinking about makeing something from scratch using trueSpace. Good luck, Rance
Tailor is definetly flukey. My suggestion is to try it again, from scratch. Go slowly and manually adjust just your morphs in Tailor ( DO NOT USE THE SET MORPHS functions, they wreck havoc). It helps to show material colors rather than the default group colors. I am on my fourth or fifth go-round trying to get the catsuit to fit Blackhearted's Elowen... it takes time an patience, but you can usually get what you are looking for. best of luck, e.d.
I'm having a problem with tailor. I'm using it to create the heavy body morph in the mil girls on some pants from lisaB. When I check the new morphs in tailor they work fine, but when I load the pants in Poser and try the morphs in it the one for the left buttock does not work. I tried exporting the morph from tailor and loading it as a morph target in poser but was told that it had the wrong number of verticies. Can anyone help me.
