Sun, Jan 26, 4:39 PM CST
Subject: Long time "Lurker" needs help
cinevid ( ) posted Thu, 20 February 2003 at 9:32 AM ยท edited Sat, 25 January 2025 at 2:09 PM
All of the sudden I'm getting an error message "Insufficient Disk Space to render at current resolution" when I try to render to a "New Window". I can only do about a 793x711 at 72ppi. Just a week or so ago I did a much larger "New Window" render that went just fine. I have a gig of ram and many gigs of free HD space on my dual 2gig Thunder AMD W2000. system. I using ProPack Enhanced P4 v 4.2.1.179. Any ideas on possible conflicts that might have arisen. I have added a few programs for DVD work.
Thanks for any help!
artistheat ( ) posted Thu, 20 February 2003 at 9:43 AM
This has happen to many times also...what I do is save it to pz3 then shut the program down...restart it and load the pz3 sometimes it works...This might have to do with the programs memory...If there is a better way of fixing this I would like to know also...
geoegress ( ) posted Thu, 20 February 2003 at 9:58 AM
one of the rsr files is corrupted- delete it- poser will make it new again
Nance ( ) posted Thu, 20 February 2003 at 10:06 AM
An ongoing problem, for which no one has found a "one size fits all" solution. Search "insufficient" in here to see the various discussions.
cinevid ( ) posted Thu, 20 February 2003 at 11:48 AM
Thanks everybody! I'll give it a shot and post what works for me.
queri ( ) posted Thu, 20 February 2003 at 12:46 PM
This id Curious Labs Memory fix for this error. It worked for me, might for you. Copied diret from their TechFAQs: Poser 4 Poser can't render high resolution images. Error appears "Insufficient disk space to render" After some intense investigation we believe we have a work around. It turns out that Windows NT 4, 2000 and Windows XP must be using some space for the pagefile.sys file on the same partition that Poser is installed, to render large images. The pagefile.sys is the virtual memory or temp space for Windows. An approximate minimum would 10 MB. This amount might have to be increased for more complex scenes and animations. The maximum should be 10 MB or greater. To modify the Virtual Memory: Windows NT 4 = Right Click my computer. Click the performance tab. Click change. Click the drive Poser is installed on. Enter 10 in the Initial size field. Enter 10 or more in the maximum size field. Click set. Click OK. Click OK. Click OK. You may have to restart the System. Windows 2000 = Right click My computer. Select the Advanced tab. Click Performance option. Click Change. Select the drive Poser is installed on. Enter 10 in the Initial size field. Enter 10 or more in the maximum size field. Click set. Click OK. Click OK. Click OK. You may have to restart the System. Windows XP = Click Start. Right Click My Computer in the menu. Select Properties. Select the Advanced tab. Click Settings, next to Performance. Select the advanced tab. Click Change. Select the drive Poser is installed on. Click the Custom size button. Enter 10 in the Initial size field. Enter 10 or more in the maximum size field. Click set. Click OK. Click OK. Click OK. You may have to restart the System. Poser will now be able to render up to its maximum size of 4090 pixels x 4090 pixels @ any resolution Emily
artistheat ( ) posted Thu, 20 February 2003 at 1:37 PM
Thanks for the info Emily:)
cinevid ( ) posted Thu, 20 February 2003 at 4:22 PM
BINGO! That was it Emily! Thanks a bunch.
