Wed, Feb 5, 4:09 AM CST
Subject: Lamp Lighting
jvia ( ) posted Wed, 19 February 2003 at 5:13 PM · edited Wed, 05 February 2025 at 4:04 AM
I'm trying to illustrate lighting from a lamp with lamp shade within a room. I've placed lights within the lamp shade and spent hours messing with the settings but I've yet to come close to the effect. Can anyone offer any advice to get me on track? I'm a fairly new Poser 5 user. Thanks!
dialyn ( ) posted Wed, 19 February 2003 at 6:15 PM
Just bookmarking for responses. One thing that may work for you is using the omnilights available from the free section. If you set the center inside, and make sure the shade has some transparency, you can get something of the right effect without it taking so much time. But I'm sure you'll get better answers than that one from others here.
Poppi ( ) posted Wed, 19 February 2003 at 8:23 PM
I've placed lights within the lamp shade and spent hours messing with the settings but I've yet to come close to the effect. Can anyone offer any advice to get me on track? I'm a fairly new okay, this may only be a small tip of the answer...but, the clue fairy tells me this. we waste tons of time in poser...(for what you are describing, i'd use bryce.) open your paint propgram, and experiment with lighting, there. poser only does so much without being a time liability.
thgeisel ( ) posted Thu, 20 February 2003 at 11:17 AM
i would try the omni light from free stuff. its a ball of spotlights and it worked for me in a similar case.Search for "lesbentley" who created it.
jobcontrol ( ) posted Thu, 20 February 2003 at 4:59 PM
I made up a simple table-top lamp from some Poser primitives (cylinders, a ball) using Dr. Geep's "1-2-3-method". The whole lighting effect is achieved with one spotlight positioned somewhere above the lamp, looking down, end-angle about 160 degrees and parented to the lamp. The "shiny" look of the bulb and the shade comes from a good tad of ambient coloring. Willy
jobcontrol ( ) posted Thu, 20 February 2003 at 5:01 PM
... and here's the principle. Spotlight above lamp, pointing down, wide open beam. Willy
dialyn ( ) posted Thu, 20 February 2003 at 5:12 PM
That's nice. Where were you when I was trying to get a candle effect?
jobcontrol ( ) posted Thu, 20 February 2003 at 5:22 PM
Thank you, dialyn! Nice to see y'all. This one is a little bit clumsy :-) It is best not to take a look too close, as for example there are no shadows from the lamp shade (I turned it off within the spotlight). This would have meant quite a bit more tinkering with more spotlights to get it right. So a candle light would have been a better example. I'm happy you found it nice. Willy
jobcontrol ( ) posted Thu, 20 February 2003 at 5:44 PM
Um, I tried ... Willy
jobcontrol ( ) posted Thu, 20 February 2003 at 5:45 PM
I confess, it looks more like dynamite just before the big bang. :-) Here's the Hair room Willy
dialyn ( ) posted Thu, 20 February 2003 at 6:06 PM
Better than anything I've accomplished. :)
jvia ( ) posted Mon, 24 February 2003 at 4:37 PM
Thanks for all the responses! With your suggestions I've been able to produce reasonable lighting.
