Sat, Feb 8, 3:19 AM CST
Subject: Small Problem
runwolf13 ( ) posted Thu, 20 February 2003 at 3:06 PM ยท edited Sat, 08 February 2025 at 12:09 AM
I'm having trouble creating a mirage effect. Any ideas on how to accomplish this?
brholte ( ) posted Thu, 20 February 2003 at 4:25 PM
hmmmmm, do you have photo shop, or someother simalar program? If so, try rendering whatever it is you want as a mirage and paste it as another layer and distort it that way.
tjohn ( ) posted Thu, 20 February 2003 at 4:57 PM
Is this what you're after? If so, this was basically done like brholte suggests, I built a scene in Bryce complete with the elements I wanted to make into a mirage. I rendered and saved. Then I removed the items that I wanted to be the mirage part, saved it under a new name and rendered again. Then I loaded both images into Photoshop (I have Photoshop Elements) and copied the mirage image onto the non-mirage image (it becomes a layer) then adjusted the transparency of the mirage and ran the Ocean Ripple filter on it (settings 3, 3). I hope this helps. Tjohn
tjohn ( ) posted Thu, 20 February 2003 at 5:04 PM
The image with mirage trees and pool of water.
tjohn ( ) posted Thu, 20 February 2003 at 5:06 PM
The image rendered with mirage items removed.
brholte ( ) posted Thu, 20 February 2003 at 6:11 PM
good job tjohn. that's exactly like I was thinking. I've never tried this, I like the idea. Kind of inspiring actually. I think I will try a mirage image of my own (hope you don't mind runwolf).
runwolf13 ( ) posted Thu, 20 February 2003 at 6:26 PM
Not at all, and yes that is what I am thinking of, only on a much smaller scale. I'm wanting it to sit right over something like a grill. So it's the effect of a mirage but limited to right over the grill. I had thought of a primative with a rippled glass texture that was almost transparent, but the edges are too defined when I try to render it. And I'm trying to do very little in post.
Zhann ( ) posted Fri, 21 February 2003 at 12:39 AM
Attached Link: http://www.unmuseum.mus.pa.us/mirage.htm
For info on exactly how a mirage is formed and an experiment you can do yourself, check the link, knowing how it's formed may help you figure out how to produce the effect in Bryce...just a thought
Bryce Forum Coordinator....
raven ( ) posted Fri, 21 February 2003 at 3:53 PM
Attached Link: http://www.shadowwindmanor.com/tutorialsbryce.html
You could always try the "Pepper's Ghost" technique described in this Bryce tutorial by ShadowWind.
