Wed, Dec 25, 1:31 PM CST
Subject: Backwards clothes? Problem with trans and other things
a_super_hero ( ) posted Thu, 11 May 2000 at 7:36 PM ยท edited Mon, 29 July 2024 at 6:14 AM
I am still working on this (I fear that it will be the end of the summer before I finish with this first 'simple' project) Right now I have a problem of the abdomen being backwards when I do a trans map. I have also included the trans map to show you what the problem looks like. The object is find in Ray Dream studio, but is wrong with the UVMapper with a planner UV Map. I have tried rotating the abdomen before going and mapping it trying various options on UV Mapper like fix seams and various combinations but with no success. It may be something simple that I just did not try, but I this newbie needs all the help he can get. Any help would be appreciated as to why part of it is backwards on one section of the clothes? Thanks. A_Super_Hero
Jackbox ( ) posted Fri, 12 May 2000 at 12:06 PM
OK 2ways to fix tis. problems is RDS no the UV Map. 1. re_create vertices & polygons, some time RDS doesnot fill polygon correctly,no display problem in RDS preview & render.but when U open itin other modeler, some polygons wl face to opp sides. U can see yr colth's obj preview in poser to found what's opp sides mean. 2. is easier, use compose 1.1 (DL fm free stuff if U don't hv it. it's poser fans' important uitilties). open yr cloth obj in compose and save abdomen wz [flip all faces] option. than del the abdo part in current group. than import the saved abdo and merged wz current file than save the whole group.I use same way to fix my obj exported fm RDS.
