Mon, Feb 10, 3:37 AM CST
Subject: max to poser woes please help
bastiff ( ) posted Sat, 22 February 2003 at 1:15 PM ยท edited Sun, 09 February 2025 at 11:40 PM
ok attacked is an image of my max render and my poser screen... as you can see in the image, the max render has the thigh high boot in the correct postion relative to the hip... after exporting and editing the .cr2 file I have made based on the judy.cr2, my model shows up in poser intersecting the hip... Now I have edited my judy model to be taller and skinnier... I manually transformed judys hip along the y axis so that I could lengthen her legs. (I dont know if this makes a dif) I have tried to get my model to work with the taller judy cr2 file and that yeilds similar results... I really just dont know what I am doing wrong. any help would be greatly appreciated Thanks in advance Bastiff
bastiff ( ) posted Sat, 22 February 2003 at 1:18 PM
oh yeah and I am currently only have 3 groups rThigh rShin and rFoot.... Does this make any difference? is it a joint editor problem? Thanks B
PhilC ( ) posted Sun, 23 February 2003 at 5:25 AM
I think you'll need to base your model on the standard figure then scale both the figure and the boot in Poser. Or keep your boot and export the scaled figure and use that as the basis for a new figure with new joint parameters. Your current problem is that you are trying to mix the two.
bastiff ( ) posted Sun, 23 February 2003 at 1:01 PM
Thanks PhilC I had a feeling I was doing the wrong thing. thanks for the help Bastiff
