Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 27 9:18 am)
If you are referring to the 'Out of Memory' error message, you need to delete the .rsr file of the corresponding obj file that you are trying to load. You will find it somewhere in your geometries folder. Can't give you much more help than that 'cause we don't know what you are trying to load when you get the error message. Sorry.
I bet you got this error after you got an error stating that Poser could not find a geometry file. You get that sometimes if you load a character and you don't have the original geometry file. Poser is not very good at telling you the real problem. You need the original item with the missing geometry file.
If you think you have the figure then the error message before the out of memory alert will tell you which object it can't read, go to the folder it specifies and delete the RSR there - NOT the RSR in the library folder, which is your thumbnail. If the folder and object aren't there at all either you have an add-on, not the figure itself, or the installation went awry, or the creator mistyped the reference for Poser.
is there a way i can increase the memory? some caracthers.. when i try them i get the message that poser has not enough memory.. ty all for your precious help! lol a newbie just starting ;)
