Wed, Dec 4, 2:14 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: - Poser/Python Export Method Problem !
gbdevo ( ) posted Tue, 25 February 2003 at 11:24 AM · edited Sat, 10 August 2024 at 6:15 AM
Hi ,
I am using the Export/import Poser/PythonModule , and particularly the Exprot Method :
Imex.Export ( suffixfile, pluginname, filepath [ , options, sceneselectioncallback ] )
What's the semantic and syntex for the 5th parameter sceneselectioncallback ? I tried a trivial call back func, with a body part selesction in it , but it doesnt work , the objective is to export just a body part of my figure .
THANKS MUCH for some ideas or informations about this case .
Gerald B.
ockham ( ) posted Tue, 25 February 2003 at 12:35 PM
The CL sample scripts include a pretty good example. Here's a minimum script, written with help from the sample, that works. (I tested it.) # ------------------------------# import poser scene = poser.Scene() imex = scene.ImExporter() # ------------------------------# def SSCall(actor): # The callback routine ~if actor.Name() == "ball_1": ~~return 1 ~else: ~~return 0 # ------------------------------# # You have to fill in the Options argument # even if you're only using the defaults. Options = imex.ExportOptions("obj", None) # Finally the actual Export call: imex.Export("OBJ","File Format OBJ", "POOO.OBJ", Options, SSCall) # ------------------------------# The callback just returns 1 for each Actor that belongs to your selection, or 0 for each Actor you don't want. Here I have supplied a certain name, but you could do a list check instead: if actor in MySels: ~return 1 else: ~return 0 Hint: If you are using a body part, you may need to run the selection on the basis of figure.Actor() instead of scene.Actor().
My python page
My ShareCG freebies
gbdevo ( ) posted Tue, 25 February 2003 at 12:50 PM
Thanks very much ocham, i paste your reply , have not seen this sample in my python scripts . I'll go to test that . It seems logic ( parameter actor in the callback and the return value 1 or 0 on the Name of the actor )and simple , that 's very well. Gerald B.
gbdevo ( ) posted Tue, 25 February 2003 at 12:53 PM
Sorry ockham, replace ocham by ockham in the previous post ;o)). Gerald B.
