Tue, Dec 3, 2:03 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 03 1:43 am)
Subject: please help a newbie out =)
korn ( ) posted Fri, 12 May 2000 at 8:02 PM ยท edited Mon, 02 December 2024 at 2:03 AM
hi everyone, i am of corse the newbie=) i have one question for now,,, i have been downloading some morphs but i cant seem to get them into poser4, how doo i get the obj file to go into poser? much thanks in advance =)
melanie ( ) posted Fri, 12 May 2000 at 8:07 PM
Go to Morph World and check out the tutorial that Traveler has. It cleared it up for me. Good luck, Melanie
Kagato98 ( ) posted Fri, 12 May 2000 at 8:08 PM
try double clicking on the body part you want to add the morph to, then click on the "add morph target" button. Go to where the morph target .obj is and then select it and it will add a new wheel for that body part to the right of the screen with whatever name you called it....I donno if I explained that as clear as possible, but there it is! I think...
pdblake ( ) posted Sat, 13 May 2000 at 1:14 AM
Kagato98 has it right. Just select the body part you want to add the morph to, then goto Figure (I think, maybe edit) and select Add Morph Target. Choose your OBJ file in the dialogue and click Enter. Give the new whell a name and away you go.
melanie ( ) posted Sat, 13 May 2000 at 8:01 AM
Sorry, I wasn't very helpful. Traveler's tutorial has screen shots to look at so you can follow. I'm a visual learner,I guess, and it helped for me :) AND MAKE SURE YOU SAVE THE FIGURE. I just saved the figure back under its original name, overwriting the original one. If you don't save the figure back to the People library with the new additions, the next time you open Poser, the morph targets won't be there. BTW, you don't have to keep those obj files on your computer. Once you've saved your figure, you can delete them so they don't clutter up your hard drive. If you've saved the figure, the morph action will stay there, even with the obj file deleted. Melanie
korn ( ) posted Sat, 13 May 2000 at 4:17 PM
well thank you all for you help, it worked out just great=)
