Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 16 10:02 pm)
I don't think you need to make the walls separate, you just need to make sure that you assign a different material to each piece of your set. Doing that will allow someone to make any one of the walls invisible (or anything else for that matter) in the material editor. You can do that for sure in UV Mapper. Not sure what you're using to do uv maps :o). Laurie
![file_48449.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_48449.jpg)
So I toasted the original and started over. The fireplace is now a full wall to make it easier for everyone. So the questions. 1 - 2,3, or full rooom for walls. 2 - I'm thinking book cases recessed into wall on both sides of the fireplace, so upper wall or from floor up. All suggestion needed. The file size is only 32kb without textures Thank-you for the help. Tashar 59
