Thu, Jan 30, 9:48 AM CST
Photography F.A.Q (Last Updated: 2025 Jan 30 8:47 am)
Subject: New scanner advice
firestorm ( ) posted Sun, 02 March 2003 at 2:55 PM · edited Sat, 03 August 2024 at 7:06 PM
hi, at christmas i was looking to get an epson photo2450 scanner but it was discontinued soon after i put in the order so i've not been able to upgrade my scanner as yet. i've been looking for reviews of the replacement scanner the photo3200 and they are thin on the ground. saw a comparative review today and now see that canon have released their 9900f scanner which just seems to edge out the epson in performance and scan quality and it is cheaper. anyone using any of these scanners or seen reviews of them. looking at getting one of them in 2 to 3 months time. any info would be helpful, thanks.
Pictures appear to me, I shoot them.   Elliot Erwitt
Artax ( ) posted Mon, 03 March 2003 at 6:49 AM
hummm... hi all... long time no see. First of all: I don't like Canon digital products of consumer level. Thay are cheap (a good point) but of low-quality in material and in problem solutions at interface and electronic level. This is the principal reason for their price. The LED system that is used in the CANON scanners (ALL the canon scanning machines) is very approssimative in detecting colors and grain. also it is very limited if you use non-bidimensional supports. for example: try to scan a watch... the LED system "catch" what is in direct contact wityh the glass but will not scan deeper. So you could lose informations from a non-perfectly plain document. The color profiles of the canon scanners (but canon printers have the same problems too) are very inaccurate. Even using an hardware calibrated monitor and using Colorsync. Epson scanners are better. so buy one of these if you could afford it. Canon scanners are wasted money if you plan to buy a mid to high quality scanner. Other choice. If you don't need a transparency adapter try to locate an Heidelberg-Hell Jade2 Scanner. you could purchase it for less than 100$ and you will have a superior scanning machine for non-transparent supports. And the software is the better piece of soft for scanning i've ever seen.
firestorm ( ) posted Mon, 03 March 2003 at 4:37 PM
hi, thanks for the heads up. canon have some new tricks on this one so i'm going to look at the reviews before deciding.
