Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 7:53 am)
As Steve said, that is a general Poser message. It just means that the pose file has a morph(s) that the cr2 does not. It cloud be as simple as a 'targetGeom shape1' that the author left in his original cr2 by mistake. The way to find out: Open the fc2 in Cr2Editor v1.51 Save a face pose of the cr2 you wish to use it on open it beside it. Compare the list of morph channels. Those in the out fc2 that do not match, expand, if the key ( k 0 X ) is X=0 for the extras, then don't worry about it, you are not missing anything.
I've had the same message when applying faces created for the original Micheal to Micheal 2. In this case, however, the face does look the same as the illustration usually. Texture maps can make a world of difference, if you texture map for Vicki is different than the texture map used to save the face with there would be a difference in appearance. A screen shot of the face in the library and the face on your model might help people analyse the problem further.
Thanks a whole lot for the helpful info. I will check it out in the Cr2 Editor and see if that helps and if not, I will be sure to check out the different textures too. Ya know that thought did cross my mind and I did try rendering one with a few different textures and they were so hillarious, I dont think that texture would have made a whole heck of a lot of a difference. LOL
I have downloaded a bunch of faces and have tried applying them to Vicki but with almost every single one I keep getting the message "Some information stored in this library does not pertain to figures of this type" Am I doing something wrong or missing something alltogether on this matter? If I click ok, it still does something to the face but not anything close to what it is supposed to look like, Its all deformed. Hope someone can help. Thanks, Annette
