Mon, Dec 2, 12:59 PM CST
Subject: Poser 5 question
methhead ( ) posted Sun, 09 March 2003 at 10:35 PM ยท edited Sat, 30 November 2024 at 10:07 AM
Why does it always say that the window is too large and that it will adjust it, then it makes all the different functions off the screen or behind the main poser figure window where I cant get to them? What is the ideal window size to use for P5? Poser 4 seems so much easier to use than this new one. Alot less options in P4 I must admit though. So what gives with the opening message saying my screen is too big?
sandoppe ( ) posted Mon, 10 March 2003 at 1:22 AM
Two things: First...make sure your monitor resolution meets the Poser 5 requirements (1024x768 I believe). That may do it for you. If not, click on "window" on the Poser menu at the top. Towards the bottom you'll see "window size". Resize the window to a size that allows you to access the tools on the right side and bottom of the screen. Once you've found a good size, select "edit/general preference" from the menu and under Document Style, pick "launch to preferred state" and click "ok". You should then be set.
