Tue, Feb 4, 10:58 AM CST
Subject: BRYCE TO LIGHTWAVE, MAYBE?
cheechman ( ) posted Sat, 15 March 2003 at 11:03 AM · edited Tue, 04 February 2025 at 10:36 AM
I was wondering, is it possible to import bryce landscape's, atmosspere's, ETC into LightWave 7.0?
Erlik ( ) posted Sat, 15 March 2003 at 11:51 AM
Landscape certainly. When you open the Terrain or Lattice editor, press CTRL+D and you'll get the export dialog box. Unfortunately, the texture won't be what you have in Bryce. So, terrains, lattices and stones. Atmosphere, no. Don't forget to make your terrains and lattices solid. Or not, depending on where you'll use them in LW.
-- erlik
clay ( ) posted Sat, 15 March 2003 at 5:44 PM
You can export terrains out via the terrain exporter along with all it's texture maps, and you can set the grid triangulation and resolution as well, select your terrain then just go to file export.
Do atleast one thing a day that scares the hell outta ya!!
Rayraz ( ) posted Sun, 16 March 2003 at 4:25 AM
"Atmosphere, no." Export directly no, but there are simple work-arounds: You could render an empty scene with a nice sky and make a 360 degree Panorama version of it to map on a sphere as HDRI-map. You could also render the sky for use as a background. If you use it only as background you should ofcoarse set the lighting in Lightwave to match the lighting of the bryce sky.
(_/)
