I then create a selection in Photoshop based on that alpha, and copy and paste. This leaves me with the hightlight on a separate layer. Then I futz with the levels, blending mode, and outer glow layer effects untill I'm satisfied.
I'd like to know what other people's methods are for capturing this effect. -- Especially for animations.
Thanks,
Scott
Scott, Have you played with Glare any? I wrote it to create just such an effect. Best regards, Eric Winemiller Digital Carvers Guild 3D extensions for Carrara http://digitalcarversguild.com
Eric Winemiller
Carrara and LightWave
plug-ins
Scott, An option here is to trace your edges of your circuit board in a Corel Draw or Adobe Illustrator, export as an .ai file and then import that line art into the spline modeler to create a shape. You can then map the texture to it using the Layer List or Projection Mapping functions. This will allow you to use Glare. I'd love to see the finished image if you ever care to post back! Mark
