Fri, Nov 8, 2:43 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 08 12:39 am)
Subject: Texture Question
amlaborde ( ) posted Fri, 21 March 2003 at 8:20 AM · edited Fri, 08 November 2024 at 12:48 AM
Hi, I have a question about making textures. I found a tutorial by Bobbie25 located here http://www.renderosity.com/tut.ez?Form.ViewPages=100&PageAction=View&Page=1
and I have found an image I would like to use for a texture. I understand the tutorial but the seam guides I downloaded from the free stuff section are Huge!!! and the image I am wanting to use is much smaller, which causes a problem when I start to clone! Can the seamguides be made smaller? Or must they stay the same size to work? Also, if they have to stay the same size, how can her tutorial be done? She says she used a picture from the internet but I have yet to see an image of a face the same size as the seam guides.
aleks ( ) posted Fri, 21 March 2003 at 8:24 AM
you can rescale the seamguides proportionally until it fits your desired texture size.
amlaborde ( ) posted Fri, 21 March 2003 at 8:32 AM
Ok cool, so it doesnt have to stay at 3000x3000? Will it still look good tho? (This is my first time attempting anything like this)
aleks ( ) posted Fri, 21 March 2003 at 8:42 AM
well, the guides will smear a bit when downsizing, but you can turn them sharper with various filters. poser doesn't fit figure's textures according to it's pixel size, but on the x/y ratio.
TrekkieGrrrl ( ) posted Fri, 21 March 2003 at 9:03 AM
The TEXTURE however will equally loose it's quality by downscaling it. Most so called hi-rez textures are 3000x3000 as this resolution has proven the best if you are to make close ups of whatever you are doing. That said, lots of times lower resolution textures can look ok as well and lower rez can be necessary if your system is lacking ram or speed or both :o)
amlaborde ( ) posted Fri, 21 March 2003 at 9:05 AM
Hmmm, okay, so where can I find good images to make textures? Also, are there any other good tutorials for making face and body textures?
TrekkieGrrrl ( ) posted Fri, 21 March 2003 at 9:08 AM
when you say texture, you are referring to a human skin texture, right? if you have, or know anybody who has a digital camera, the easiest is to simply take some photos. There is also one or two packs in the market place that sells such photos. Not sure if they're any good, I haven't tried them and the human textures I've made has been some that I have painted, not photorealistic in other words :o)
amlaborde ( ) posted Fri, 21 March 2003 at 9:37 AM
ahh, I see and yes I am referring to human skin texture. Maybe I will check out the marketplace packages, maybe scanned magazine pictures would work also?
TrekkieGrrrl ( ) posted Fri, 21 March 2003 at 10:39 AM
They MIGHT work, but often when you scan magazines they have raster on the pictures. While these are not really seen under normal circumstances, they WILL stand out in a texture. But depending on method used for the magazines, it COULD work. At least I think so. :o) Good luck.
amlaborde ( ) posted Fri, 21 March 2003 at 10:50 AM
Thanks a bunch!
ladynimue ( ) posted Fri, 21 March 2003 at 11:44 AM
Try taking photographs of your friends and family. Adjust the scanning size to fit your "seam-guides" :) ladynimue
amlaborde ( ) posted Fri, 21 March 2003 at 12:32 PM
Thanks ladynimue :) Maybe I will do that. I have a cousin that would make a great texture. LOL
SamTherapy ( ) posted Fri, 21 March 2003 at 12:45 PM
If you are scanning magazine pics, you can filter them in Photoshop to get rid of the process dots and patterning. First, scan them HUGE. You want to be scanning at a res of no less than 300 dpi. Then, drop the resulting files into Photoshop and use Gaussian Blur. Start at a value of 0.8 and increase until the rosettes start to merge. I'd also recommend you increase the contrast by about 16% and brightness anywhere from 10%-20%. Save out your new pics at a manageable size. In truth, I haven't ever tried to use scanned images in this way, but I do know how to scan pics to get a good result on screen. A final tip - despite what your scanner manual or the software help file will tell you, never use a white sheet behind the pic when you scan. You will get much better results if you put a sheet of black paper behind the pics. It will help prevent the images or text from the other side bleeding through onto your image.
amlaborde ( ) posted Fri, 21 March 2003 at 1:01 PM
Wow, that black paper behind is a great tip. Never thought of it before. :) Thanks. And I think I will experiment with bot the camera and scanner images. I will make sure to follow your scanner tips. My scans always come out somewhat choppy.!!
Lyrra ( ) posted Fri, 21 March 2003 at 6:15 PM
Unfortunately, if you are using scanned in magazine images, be aware that thos images are copyrighted. So you won't be able to sell your texture, if that's what you have in mind at any point. Photographs are your best option ... I believe SydRaven has a great tutorial on photogrphing for skin textures over at RuntimeDNA
