Forum Moderators: Staff
MarketPlace Showcase F.A.Q (Last Updated: 2024 Nov 22 9:03 am)
Thanks for the comments... the lace/texture is applied (via included MAT pose files) to the 'transparency' map... I supply 3 MAT pose files to set the color to Black, Red or White, but you can also easily just set the object color in the materials dialog to any color you wish.
Cinema4D Plugins (Home of Riptide, Riptide Pro, Undertow, Morph Mill, KyamaSlide and I/Ogre plugins) Poser products Freelance Modelling, Poser Rigging, UV-mapping work for hire.
BTW, just to clarify something... in the first image above, I used the same lace texture as both a transparency map and a bump map... the bump map adds some detail.
They sure do!
What we do in life, echoes in eternity.
E-mail
| Renderosity
Homepage | Renderosity
Store | RDNA
Store
woooo-hooooo!!! they are soooo kewl, thanks for making them for us ;) goes off to make the first purchase of the day -=S=-
Oh just wondering, they have a 'garter tug' morph to them, will there be a garter belt, or do they match up with any already out there? Also.. do they only fit V3's defult legs?
One of the Garter Tug morphs would make it compatible with the layout of Billy-T's lingerie set (for V2), which has the rear strap more on the side of the leg. The other morph has the rear strap pretty much directly to the rear, opposite the front strap (I actually didn't know about PhilC's lingerie until I had uploaded my package, but from his images, it may be compatible with his straps). As for whether there will be a garter belt... while I have some things in development, I don't have anything ready to publish just yet ;). As to fitting - yes, currently, they fit the default legs, with a few adjustment morphs, but none of the v3 'character' morphs are included. I may provide those in an update if there's enough demand. - Keith
