Wed, Nov 27, 6:13 PM CST
Subject: How do you Render to DV specs?
krbtv ( ) posted Sun, 21 May 2000 at 10:55 AM ยท edited Sat, 10 August 2024 at 12:38 AM
In Poser 4 when you select Render,Options and place a value in the width/height they both take on the same values. (I have is set for pixels). How do you determine the resolution? The only thing I can think of is to make the width/height 480 (pixels) and the resolution 720. DV is 720x480. Is their any way to mimic that using Poser? Thanks in advance.
earnest ( ) posted Sun, 21 May 2000 at 1:07 PM
Double click on the window dimensions (350 x 350) (top right of document window). This brings up Set Window Size dialogue box. Key in Width 720 Height 480. Check Constrain aspect ratio. (This will allow you to resize the window whilst keeping the correct DV proportions). Now when you Render to new window and key in Width 720 pixels Height will be automatically set to 480 pixels. Good luck
krbtv ( ) posted Sun, 21 May 2000 at 1:47 PM
Thanks. It works. What should I enter for the resolution?
