Fri, Jan 10, 3:57 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
Subject: Poser Hierarchy File
brian71us ( ) posted Sun, 23 March 2003 at 2:49 PM ยท edited Thu, 25 July 2024 at 5:21 AM
Is it possible to easily create a Poser Hierarchy File from an existing CR2 ? Brian
PhilC ( ) posted Sun, 23 March 2003 at 4:10 PM
The information is contained within a CR2 file, just search for "addChild". You will still need to hand edit it into the format required in a PHI file. If you could tell us why you want to do this we may be able to advise you better.
brian71us ( ) posted Sun, 23 March 2003 at 5:40 PM
I am trying to create a character (or characters) using Victoria 2, but the CR2 is rather large. The procedure I have in mind (roughly) is: 1. Create the character by setting the morph dials, etc. 2. Export the figure as an OBJ 3. Re-import the OBJ and turning this into a poseable figure 4. Using Morph Manager or the Pro Pack to apply only those morphs that are absolutely necessary (elbow fix, etc.) In this manner I could create a "barbarian" character that no longer required the morph target(s) data in the CR2 file. I tried going into the Setup room and clicking on the Victoria 2 button, but this loaded all of the morph targets again! Of course, I could not distribute a character made like this for obvious reasons. Or is there an easier way?
PhilC ( ) posted Sun, 23 March 2003 at 5:59 PM
I think what I'd do is just use Morph Manager to delete out all the unwanted morphs to reduce the file size. If you try to apply the morphs to the amended body shape I think the results will be accumulative.
