Sat, Jan 25, 11:42 AM CST
Subject: new need some help
theecoop ( ) posted Fri, 19 May 2000 at 6:42 PM ยท edited Fri, 10 January 2025 at 6:07 PM
how can i take a scanned photo and place it on a poser 4 face ? i have rhino3d (which i'm more use to using ) studio max,and paint shop pro....I mainly need to know what files need to be edited and if their is anything that has to be converted in any way first or after. Thanks in Advance Theecoop
Kalypso ( ) posted Fri, 19 May 2000 at 7:18 PM
Site Admin
In your Poser directory in the Textures you should find the textures for the P4 man and woman in the P4Textures folder. A good way to start is by taking this in PaintShop and pasting the photo of the face you want on the map. Make sure you line up the face correctly, you may need to render and try it first. Of course other changes might be necessary to make the colour hue of the face match that of the body and so on. I don't use PaintShop though so I don't know how it handles layers, etc, but there is a forum for it check on the right.
theecoop ( ) posted Fri, 19 May 2000 at 7:53 PM
Thanks a lot i'll try that Theecoop
theecoop ( ) posted Fri, 19 May 2000 at 9:09 PM
well I was able to modify tif ok.saves it over as original having a back up of it first thought...then went in to poser 4 to load it but see no change .any idea what i did wrong?
polar ( ) posted Sun, 21 May 2000 at 4:49 PM
did you RENDER the inmage? Textures only appear when rendered.
theecoop ( ) posted Sun, 21 May 2000 at 7:50 PM
thanks i found that out it worked.
