Tue, Feb 4, 8:28 PM CST
Subject: Morphing Face Mask Question
Cylithera ( ) posted Wed, 26 March 2003 at 12:50 PM · edited Mon, 27 January 2025 at 6:28 AM
Is it possible to apply a face morph to the mask? I mean, it doesn't seem so, because I tried applying the Darla face morph to the mask. And, well it doesn't work. Is it suppose to? Any help is appreciated! ;D
RHaseltine ( ) posted Wed, 26 March 2003 at 1:00 PM
If it's a custom morph (actual new vertex positions, via an OBJ file or an injection pose) then no. If it uses the DAZ morph packs then yes - select the head, edit>copy, select the mask, edit>paste and if the head had been moved from it's zero position re-zero the mask's translation values.
Cylithera ( ) posted Wed, 26 March 2003 at 1:16 PM
Thank you, thank you! I had no idea about that! Thank you very much! hugz ;)
PheonixRising ( ) posted Wed, 26 March 2003 at 1:52 PM
Also if you have P4 or Propack you can apply v3 face files(.fc2) directly to the mask.
-Anton, creator of ApolloMaximus: 32,000+ downloads since 3-13-07
NEW The Poser FaceInterMixer
Cylithera ( ) posted Wed, 26 March 2003 at 10:44 PM
Oh. It has to be a face file, huh? I was trying to apply a pose. Thanks! ;D
PheonixRising ( ) posted Thu, 27 March 2003 at 11:29 AM
A pose will work too but just one that turns dials...the inj/rem won't work since there is have a head mossing from the mesh.
