Make sure you have the object file in Runtime:geometries:hair folder Look there and delete the rsr file if using P4 then try again. Remember the long hair is a conforming object so conform it to V2. Also, there are mat files included for the appendix version also under Koz_long_appendix. The names don't all show in the Pose library. The conforming one starts with Mat_Koz. Hope that helps.
I also have not been able to see the conformable hair when it is loaded. I am trying to conform it to Posette rather than Vicky, but there is nothing at all visible in the scene ?? I'm on a Mac so rsr's don't cause any problems. I also had the same problem with the conforming Hollywood hair from Jim Burton. It would seem to load but remained invisible,
Hi - When I load Koz's Long Hair for Vic2, I get no visible file. Certainly there's nothing by her head. I've been able to get the Koz Long Hair Appendix to load and then changed the y tran to fit Vic but most of the MAT files I have for the hair are for the Hair Figure and not the hair Prop Figure (which the appendix version is). Anyone else having trouble with the CR2 version of the hair? Dave
