Attached Link: http://http://www.3dcommune.com/3d/galview.mv?Bryce+oYfHa84VI+0996063023
i don't know if you need to sign up to see it thoughAttached Link: http://www.3dcommune.com/3d/galview.mv?Bryce+oYfHa84VI+0996063023
This one was tough. I was having a hard time trying to figure out where the error was, I found it.I've used trees in the past to simulate waves, and with patience it can work.
Here's an old thread on that topic.
Here's a WIP using that technique.
Hope that helps!
Forgive the html overuse in this post ;)
thanks.. ya i wondered wat was wrong.. i saw the double http:// thing so its ok.. that thing is pretty good.. but i really gotta sit down and concentrate on it.. cause its not really step by step.. but ya ill get i hope.. but im not sure if bryce has anyone of putting into macromedia flash.. anywayz thanks alot again.. cya
hi there.. i really want too make a beach waves.. where the camera is above the image.. and it hits the beach.. now hopefully someone knows a good way of doing this in bryce.. because i then want too transfer it from byrce.. or find a flash plug in... cause i really need it for flash.. cause its way to hard too do it in flash alone.. ok hope someone helps.. if u suggest maybe 3d studio max with the swift plug in is the better way too go.. can u plz leave any tutorials so i might be able too look up.. ok thanks again.. firstly for reading and anyone that replys with information.. cya
