Tue, Feb 4, 3:35 AM CST
Forum Moderators: Staff
Subject: after creating 3dm in rhino
theecoop ( ) posted Mon, 22 May 2000 at 8:54 PM · edited Sat, 25 January 2025 at 11:55 AM
need to know what steps are needed after i make an obj in rhino..export as Nurbs,polygon mesh and trims as polylines or curves.then how is a cr2 and rsr file created ....trying to make some old rhino pieces to work into poser 4
KenS ( ) posted Tue, 23 May 2000 at 7:15 AM
I use Nurbs and curves to export as, when they are imported into Poser and saved, then the .cr2 and .rsr are generated
theecoop ( ) posted Tue, 23 May 2000 at 10:24 AM
thanks for the info
