Sat, Nov 9, 10:21 AM CST
Bryce F.A.Q (Last Updated: 2024 Nov 08 7:02 am)
Subject: Dual Display Question
Jaymonjay ( ) posted Sun, 30 March 2003 at 12:28 AM · edited Sat, 09 November 2024 at 10:02 AM
Me again. :) One quicky question: I am running dual monitors and would like to use one to hold all of the Bryce toolbars and the other as the working area. Now, I can move the toolbars to the other display just fine, but am wondering if there is a way to make the working area fill the entire other display. I tried bumping the resolution (ie. 800x600 to 1280, etc.), but the size of working area did not change, just the view within it. Is there a limit to how big it can be?
clay ( ) posted Sun, 30 March 2003 at 2:54 AM
Simple answer Nope:-)
Do atleast one thing a day that scares the hell outta ya!!
Jaymonjay ( ) posted Sun, 30 March 2003 at 11:28 AM
Nope.... nope? Nope: You cannot fill the entire screen with the working area, or Nope: there is no limit to the size of the working area? ;)
Aldaron ( ) posted Sun, 30 March 2003 at 11:45 AM
Make sure the interface is at maximum (on the right side is the toggle) then go to document setup and select the size you want (screen resolution size?) and it should work.
Claymor ( ) posted Sun, 30 March 2003 at 11:43 PM
I would think you could do file-document setup and then select max recommended. I haven't used duel displays but it works to get the work area bigger on a single display
Jaymonjay ( ) posted Mon, 31 March 2003 at 12:15 AM
Well, it sorta works. I can get the working window to grow just ok. Now, if I can only figure out how to make the damn thing centered in the screen. :(
