if they are in Obp format HIt "Create" when the objects menu comes up -Hit "Import" on the bottom of the little screen - then find the file (.Obp only) select it and there you go It will apear in the menu so any time you want to pull it up just go in the object menu - if the objects are in other formats in the main menu select "file" - "import object" find the file and there you go . I hope I was clear - good luck roch222
Another thing to watch out for here is that the models aren't poser props or figures... bryce doesn't deal with poser's prop files (.pp2 ?) unless you can use poser to convert them into another more bryce friendly format like .obj.
Digital
WasteLanD
Speaking of Bryce objects, I take it that B5 .obps don't work in B4... It would be nice if that was more clear when such things are posted. I was dissappointed that when I went to add some of them that it said error or unreckognized file format. Just so you know, there are still pluggers out there (like myself) who still use the old Bryce. (I'm waiting for the version that has a bit more than metaballs and trees.) On the other hand, I presume that the old Bryce 4 .obps work just fine in Bryce 5?
I downloaded some mesh's and a couple of models from the freestuff section now how do I use/install them?
