Fri, Dec 27, 2:04 AM CST
Subject: Freeing Iraq update....
Swade ( ) posted Thu, 03 April 2003 at 9:30 PM · edited Fri, 27 December 2024 at 1:42 AM
UPDATE: I have changed the camo to desert camo and have added smoke to the buildings that are in ruins. I have yet to figure out why my tents all look as they were copied and pasted.... the pattern seems to be the same on all 3 of them. Criticisms are welcome.
There are 10 kinds of people: Those who know binary, and those who don't.
A whiner is about as useful as a one-legged man at an arse kicking contest.
Emberghost ( ) posted Thu, 03 April 2003 at 9:59 PM
maybe to make them look different you should go into the deep texture editor and edit the colors on each slightly to give them a different appearance. Give that a try.
Aldaron ( ) posted Thu, 03 April 2003 at 10:02 PM
If they are procedural textures try rotating them on onw of more axis but it'll probably have to be set to object space mapping, not sure it'd work on world space.
Claymor ( ) posted Thu, 03 April 2003 at 10:16 PM
If you change the scaling on the textures on the tents and/or move them slightly in a single direction it will make them look different.
Kylara ( ) posted Thu, 03 April 2003 at 11:53 PM
I would change the texture type of all 3 to world-mapping instead of object-mapping.. that way the pattern won't repeat itself either and there's enough space between them that you won't see the texture running through all three tents
GROINGRINDER ( ) posted Fri, 04 April 2003 at 4:41 AM
Attached Link: Prop blur tut
Here is a tut to make more realistic prop blurs.
GROINGRINDER ( ) posted Fri, 04 April 2003 at 4:44 AM
I sure hope the Iraqi people embrace freedom and democracy and don't let another dictator rule their country. I fear that it will become another fundamental muslim state instead of a secular one.
lsstrout ( ) posted Fri, 04 April 2003 at 1:18 PM
I fear that the rest of the world won't give them the support they need in order to reach that goal. Excellent picture Swade, the changes look great and if one of the texture suggestions work, then your tents will look even better. Lin
