AFAIK, Tiziana (which I don't have) uses the same morphs as Perfect G (which I do have), so the principles are the same. The morph uses its own textures, but integrates them with any body texture you care to use. It does this in such a way that the transition looks very smooth and quite natural. Well, as natural as the current state of Poser graphics can be for such things. The way it works is this... You're provided with a Photoshop layered file which you use to merge in the new pubic area tex with your existing tex. There are reference points for scaling, so the whole thing blends in well.
Hi, I'm looking for some feedback about the Tiziana v3 gen/hip morph from someone who has used it with very high res textures. Question is: Does the morph use its own textures which will obscure the original high res pubic area textures? If so, wouldn't this look a little bit strange/unnnatural - kind like a 'patch over' or something? Or does it somehow integrate textures in that area smoothly with the best of the highres textures available elsewhere? many, many thanks for any info here....
