Sun, Feb 9, 3:09 AM CST
Forum Moderators: Staff
Subject: What is an injection Builder?
RNKarenER ( ) posted Thu, 03 April 2003 at 10:50 PM · edited Mon, 03 February 2025 at 12:00 AM
I am working on a Vic 3 texture. All is fine, the texture is almost done. Now, I have the face morph.. I have been told that I need to use a injection builder. Only , I have no idea what it is... Any help???? Karen
lesbentley ( ) posted Fri, 04 April 2003 at 4:51 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=968818
You can build your own morph (delta) injection pose using a text editor. The link above may help to explain how it is done. You can use the same pp2 to inject the morph and the texture if you want.
lesbentley ( ) posted Fri, 04 April 2003 at 5:01 PM
These links are also on the subject. http://www.renderosity.com/messages.ez?Form.ShowMessage=763920 http://www.renderosity.com/messages.ez?Form.ShowMessage=547662 http://www.renderosity.com/messages.ez?Form.ShowMessage=606841
Jaager ( ) posted Sat, 05 April 2003 at 11:29 AM
InjectionPoseBuilder is a small program that Rob Whiz wrote for use on V3. It is $2 at DAZ-PC. If you save your face as *.fc2 - the program will read it and automatically generate a file that will inject just the morphs that you used and set their dials. It will also generate a REM version. It is automatic for DAZ morph sets. It has a manual entry that will generate readScript lines for 3rd party morphs. It saves you a lot of work, or from having a user need to use a version of V3 with all head morphs injected so that your dial set fc2 pose will work, if you do not want to do your own readScript by hand. It is efficiency.
Staale ( ) posted Sat, 05 April 2003 at 12:30 PM
Attached Link: http://home.online.no/~kjellil/Index-AllStuff.htm
If you have made your own morphs then you could use the beta of my 'Pozers Little Helper - Full .obj to Morph Injection' app found here: http://home.online.no/~kjellil/Index-AllStuff.htm It's PC only.
