Tue, Dec 3, 1:50 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 03 8:59 am)
Subject: Two newby animantion problems?
bmnb123 ( ) posted Fri, 04 April 2003 at 9:47 AM ยท edited Tue, 03 December 2024 at 1:40 PM
Hi I am new to animation with poser 4.
I having to problems the first is. when I use any of the pre pare walkdesinger my character is rases up in the air.
My second problem is when I try to do animation it fells jerky to me I have tried setting it to different interpolation the only one I remotely dot to work is constant but it does not look right I have tried skip frames and res ample key frames with little I also tried different key frame combination 30, 60, 90, ETC. I grateful it if anyone has any idea what I am doing wrong.
thank you for your time!
HaiGan ( ) posted Fri, 04 April 2003 at 11:12 AM
Does it look jerky when you view it in the preview screen, or in the rendered movie file? If it's in the preview then your machine is probably just a bit too slow to display it smoothly. What's it like using fast tracking?
danae ( ) posted Fri, 04 April 2003 at 12:15 PM
Be sure that the skip frame box in the animation controls is not checked. 'Skip frames' is a feature in playback that previews the animation skiping several frames a second. When you render you should be able to render with the normal 25fps (or whatever you have chosen) regardless of if this feature is selected or not.
bmnb123 ( ) posted Fri, 04 April 2003 at 6:23 PM
you are right it is my system athlon 1800 with 750mb ram not up to the job I plan on getting a 2600 soon. Thanks
