Thanks kix, I gave that a try but it did strange(almost arcane)things to my model. I wouldnt mind the facets so much except that I need to line up some other pieces to this one and the facets are going to make it difficult. If you have any suggestions on how to make something like this without resorting to a boolean operation..feel free. :o) Cheers, Max
This works in RayDream and I assume it does in Carrara as well. Before doing a boolean on a spline object, make sure surface fidelity is set as high as possible and then either convert to a mesh form object again with maximum fidelity with the Edit in another modeler option OR export to a DXF and re-import. I've had success with each technique in increasing the resolution before the boolean execution.
My Store - My Gallery - My Freebies - My Web Site
-Kix
Thanks everyone. This has really helped. I just got back to my computer after a weekend away form the keyboard. Ill hopefully have a little time to take another crack at this today. In case youre wondering, the whole image Im working on is a vintage style microphone. Thanks again for all the info. Cheers, Max
I may be a little dense here, but Im having trouble getting the end of the inner opening to curve. I placed all the cross-sections, that was easy,so at this poing Ive got the opening, but the ends are straight lines and come to a pointed end. Now how do I get that part to form a curve? Sorry if this sounds rather convaluted, I hope my explanation makes sense to someone. :o) Cheers, Max
