Ok, I got both softwares at the same time. So, bare in mind that I'm novice with both of them. :) ... I have Poser 5 and Vue 4 (to be precise, Vue 4.06-02, don't know if it makes any difference though). Using in PC with Windows XP. I can't import Pz5, so tried both OBJ and 3DS. Unfortunately I don't know how to add pictures in this message box. :( so, can't actualy post an example. In the mean time, I'll go ahead and look into the FAQ section; thanks.
BINGO!! Update your Vue version to 4.12 anyhow to get correct support here. Poser 5 is a problem with Vue 4 if you don't have Poser 4, but some users can do it. You may do a search for "Poser 5" here in the forum. This was already treated very often. To add a picture to forum posts, Browse the ATTACH FILE when writing an answer and find the image to upload on your HD. :-)Guitta
The reason behind the dull look comes from the default settings in Vue (Bryce has the same problem). - Check the atmosphere settings. Especially useful to get rid of the dullness are 'exposure' and 'ambiant light'. If you reduce both, your image will look darker but the colors will be more realistic. - Next you will have to compensate that darkness by adding more lights to your scene. Try placing some point lights, with low intensity (50) and shadow/flare turned off. Two or three of these lights will enhance your scene. I will try to find some URLs I had to illustrate this when I get a chance.
Attached Link: http://market.renderosity.com/%7Evue/archtips.html
This link is for the Vue FAQ. Check under lighting tips.When I import poser people, I up the ambiance and diffusion a bit on the skin textures and hair, depending on the lighting of the scene. If I want the hair on my person to be blond, I go even higher with ambiance and diffusion, and sometimes add a very slight glow effect. You can also try color blends in the texture editor. That's a good thing to know if skin or fabric doesn't look well with the rest of the scene. Of course, I've been using poser 4 but this may still hold with poser 5 imports. Not sure tho. But it works for figures that were created in Poser 5 and are not supposed to be used in Poser 4. Oh and you'll have to fiddle around with the bump maps too. A bump gain can be very slight, like 0.050 and have a nice effect, depending on the figure, whereas the default gain of 1 will make it look horrible. Good luck! :-) Linda
nish... you will have more control if you tweak the materials and textures after importing into Vue. I don't think those parameters are exported from poser.
Attached Link: http://www.3drender.com/light/3point.html
Here is the link I was talking about to illustrate basic lighting techniques. It is taken as a tutorial from a book I cannot recommend enough if you are interested in texturing and lighting in 3D.Attached Link: http://www.warpedspace.org/lightingT/part1.htm
And here is another similar reference.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Ok, when I import a poser character into Vue, it looks very dull & fake. How can I prevent it from happening? Or perhaps what can I do to restore the quality of import? Umm, I'm not sure if I made myself clear. Please, some advise would be greatful.
