Forum Moderators: Staff
MarketPlace Showcase F.A.Q (Last Updated: 2024 Sep 20 10:50 pm)
Attached Link: Pulling in to the MP any day now.....insertion point HERE
Another shot, showing the poseable winch arm and winch assembly. The winch assembly also has a morph for extending the winch.Attached Link: Abrams, HMMWV and Scud.....all HERE NOW!!!!!!
Also available, the M1 Abrams main battle tank, and the HMMWV, armoured recon version. We also have a Soviet Scud mobile launcher, and next week sometime should see completion of the T-72 heavy tank.Yes, it's one tough old bird. The US Army was trying to replace it with the Stryker, a wheeled PC, but it's performance wasn't any better. It comes with several different kinds of gun mounts, with and without shields that don't impact on the basic hull. I had an M113 driver that crashed his M113 into the final drive sprocket of an M88, cracked the hull which totaled the M88 for all practical purposes.
Gordon
A few notes for further development. The antannae are located closer to the edge of the hull. The top hatch (not shown on the model) should be movable and is normally in the open position. In Germany, one trooper normally stands in the back with a stick with a paddle red and green sides, called the "Machs Nichts (Mox Nix) Stick) to warn motorists if it is safe to pass. The standard mount is a pintle mount that swivels with the hatch in 360 degrees around the TC hatch (Track Commanders). The rubber skirts covering the top of the tracks is often missing in combat. They were for increasing the traction of tracks in water. A trim vane is in front, normally in the up or stored position ... seen now covered with junk. Gulf War2 variants show a number of boxes fixed to the sides. As combat vehicles go, this puppy has been around forty years in the hands of troops. They were gas burners at first, by Vietnam, they had diesels. I once saw a German M113 with a Mercedes engine in it ... it hummed, ours clanked.
Gordon
Engine compartment has (removable) walls on drivers side and one facing the rear. Diver has seat which can slide up or down depending on whether the driver wan't his head out of the hatch or through the vision blocks. There are drop down seats attached to interior bulkhead which in turn are stepped to accommodate the tracks on the outside. These are some I took in another life
Gordon
Attached Link: Find it HERE in the next few days
Available in the next few days, the 3dmodelz M88a1 ARV, as seen on television worldwide in the last few days pulling down a certain statue. High quality poseable cr2 figure.
