Sun, Nov 24, 1:35 AM CST
Subject: DYNAMICS SYSTEM RELEASE
MASA ( ) posted Sat, 27 May 2000 at 3:40 AM ยท edited Fri, 22 November 2024 at 7:52 AM
I produced a dynamics system for POSER4. The system name is "PAE". The main function is as the following. -Joint interlock MT control -Gravity perception -Inertia simulation -Acceleration simulation -Centrifugal force simulation dynamics terget main is chest and hair. Sample movie(Nudity 314Kbyte) is as the follows. http://www.eurus.dti.ne.jp/~masasi/PROGRAM/PAE/SWAYING.mpg the system run only Win9x. I do not know whether PAE run on english Win9x or not. Isn't there anyone who try use my system? Could you tell me about your impression? Yamato produced Nene Lite model. Lite models are modified to be the most suitable for PAE. incredible stuf. You can get PAE and NeneLite from my site. http://www.eurus.dti.ne.jp/~masasi/ (System -> P.A.E(ENGLISH) -> about DOWNLOAD) I AM JAPANESE.I HOPE YOU WRITE SIMPLE ENGLISH PLEASE. MASA
JeffH ( ) posted Sat, 27 May 2000 at 6:29 AM
I will take a look at your files and tell you if they will work. I'm not sure I understand the dynamics system yet, but I will give it a try. -JH.
MASA ( ) posted Sat, 27 May 2000 at 10:09 AM
JeffH, I express my heartful thanks to you. If my system is hold good,I will produce next version. MASA.
JeffH ( ) posted Sat, 27 May 2000 at 11:02 AM
I tried it out with WIN95B and it was stable until I attempted to save the PZ2 file, then it caused a page fault. I re-started it and it was successful the second time. If anyone want to know, this program is much like MIMIC. It uses propietary morph targets to create the effects of gravity and motion on the body (breasts and hair). I hope others will try it out report back. -Jeff H.
Ghost ( ) posted Sat, 27 May 2000 at 11:49 AM
if you say its good jeff then here i go! i'l lreport back on it!
MASA ( ) posted Sun, 28 May 2000 at 6:45 AM
JeffH, Thank you for report on it. page fault? it is the unconfirmed report. I check my system algolizm. My system is no ploblem on Japanese Win 95 4.00.950B. Ghost, Thank you. I hope you will kindly look after my system. MASA.
JeffH ( ) posted Sun, 28 May 2000 at 8:11 AM
Yes it threw a "page fault", I'm not sure why. -JH.
Jim ( ) posted Sun, 28 May 2000 at 9:26 AM
I just played it on Win 98 with new Media Playeer 7 and it worked flawlessly. Good work Jim
