Mon, Jan 27, 8:58 AM CST
Subject: Newbie Question
minnie25 ( ) posted Wed, 16 April 2003 at 4:14 AM · edited Sun, 26 January 2025 at 6:55 PM
just a simple question to all your pros out there...
How do I open the mouth on my figurines (where you can actually see their teeth)?
I tried in the face room but I can't find the right button :)
Any suggestions?
Thanks
raptorweb1 ( ) posted Wed, 16 April 2003 at 7:11 AM
go to display and check to display the dials and when you click the head you should find dials to adjust how you want it.
cruzan ( ) posted Wed, 16 April 2003 at 7:17 AM
You should be able to morph the mouth in the objects properties window. If you are using one of the Daz people or the people that came with the program, in Poser5 - select the head and left click on menu item Object then Properties. If the character you are using has the morphs for mouth you can adjust them here. In poser 4 you should see on your right a bunch of dials. I usually start with mouth open or mouth O dials and then Smile dial for early models. If you do not see these controlling dials for character then the character wasnt designed for that and you will have to go to a 3d modeling program to make changes - would be easier to switch characters ;-)
cruzan ( ) posted Wed, 16 April 2003 at 7:20 AM
oh yeah, the properties box where the dials are has 2 tabs: Parameters and Properties. Click on the Parameters to see the dials. Sorry for cross post.
minnie25 ( ) posted Wed, 16 April 2003 at 7:21 AM
(nm)
ockham ( ) posted Wed, 16 April 2003 at 9:59 AM
For what it's worth, showing teeth is not easy. It depends on the combination of face morphs available, and the native Poser models don't do it very well. Vicky 3 does a good job of showing her teeth. One hint: sometimes it's easier to adjust the Teeth or Jaw morphs rather than the Mouth. Not the "natural" way, obviously!
My python page
My ShareCG freebies
