Sat, Jan 25, 2:26 PM CST
Subject: Bryce Import Problems
Enternal_darkness ( ) posted Thu, 17 April 2003 at 7:28 AM ยท edited Sat, 11 January 2025 at 12:49 AM
Greetings All, Im having some problems with Importing a 3D Studio MAX file into bryce. the picture shows the car in MAX, and then what it looks like after importing into bryce. I dont have a problem with retexturing in Bryce but im wondering if there is an easy solution to put the objects back together in one go rather than having to rescale, re-align and re-position them all induvidually as i have already began to start this but gave up...
tjohn ( ) posted Thu, 17 April 2003 at 8:06 AM
I didn't think Bryce would import .MAX files at all, just .3ds. I have had some similar problems importing certain .3ds files but for the most part they import quite well. Perhaps if you can put the file through another program and convert to .obj or .cob, which Bryce seems to have less trouble with. Someone in this forum will know for certain. Good luck!
Flak ( ) posted Thu, 17 April 2003 at 8:21 AM
Yeah, I've had that sort of problem with one or two .3ds files as well. .obj files on the other hand, I've never had a problem with.
Digital WasteLanD
tcdrushgeddy ( ) posted Thu, 17 April 2003 at 9:27 AM
Man, I have had the exact same problem on more than one .3ds file. Seems like the larger ones tend to have the most trouble. I have not even considered repositioning and scaling. Some of them are impossibly out of kilter. Converting to .dxf has fixed some of them, but then its a huge file, and one big object that can't broken up and textured etc.
tcdrushgeddy ( ) posted Thu, 17 April 2003 at 9:37 AM
Well, I guess you could try and group the objects in MAX and export them as .dxf's as you want them to appear in Bryce. I don't know much max so I have not tried it.
raven ( ) posted Thu, 17 April 2003 at 10:22 AM
Attached Link: http://www.habware.at/duck4.htm
Depending on the version of Max (3 or 4) you could try the habware .obj import/export plugin to save it as an .obj file.
tcdrushgeddy ( ) posted Thu, 17 April 2003 at 11:46 AM
just tried raven's idea (the plugin) with max 4 and it has fixed the problem on one file that was giving me problems! Thanks raven, this issue has been very aggravating!
Alan-ASD ( ) posted Thu, 17 April 2003 at 1:46 PM
I don't know if this will help or not... I don't use 3D Studio Max. I'm using Lightwave, Rhino and a little Maya. I've worked with importing quite a few .obj and .3ds files into bryce and have found the following to be true: - The larger the file size the more likely Bryce is to screw up importing it. Therefore, I export individual parts of the model as separate files from the software inwhich it was originally created. The trick is to first create a simple box around your entire model and to include it with every part of the model you export. By including the box your ensure that every part of the model will import into Bryce in the proper place and at the proper size. Then I just delete the boxes in Bryce. - I prefer using .obj files simply because it eliminates the need to mess with smoothing the model in Bryce. However, .obj files are usually larger then .3ds files; so if file size becomes critical I will use .3ds instead of .obj.
Hepcatbrandon ( ) posted Thu, 17 April 2003 at 6:34 PM
Good trick Alan. Sounds like a better alternative to waiting 3o minutes for a model to import and then getting an error message.
