Sat, Feb 8, 11:18 PM CST
Subject: experiments in light & realism.
ICMgraphics ( ) posted Thu, 17 April 2003 at 4:27 AM · edited Sun, 02 February 2025 at 4:09 PM
After a gallery posting comment from jstsittinghere on "Star Census" , and the string posted here by Kiera on Vicky Realism, I thought I'd experiment. Far top right is the gallery posting. "c & b" are one light and "a" is the same only tweaked in photoshop.(2 layers, one grayscale with color overlay sharpened) "d" is with 2 lights. Deosn't come close to the realism of poser 5, yet it's not to shabby, best I've ever done.
ICMgraphics ( ) posted Thu, 17 April 2003 at 4:29 AM
Oh yeah secularity was turned up to 22 in b & c
oops, Specularity
ICMgraphics ( ) posted Thu, 17 April 2003 at 6:55 AM
This one all white w/true amb
Kiera ( ) posted Thu, 17 April 2003 at 7:12 AM
I think B & C look pretty good. Looks like you need some more bump though. Mike can look pretty good, but you can see his polys, particularly on the skull, which makes realism more difficult to achieve. The brows are a touch over-exagerrated. Maybe tone them down a tad.
TheBryster ( ) posted Thu, 17 April 2003 at 8:59 AM
Close to realism, very close. He still looks a bit 'modeling clay' IYKWIM..... Better than anything I could do........ The Bryster
shadowdragonlord ( ) posted Thu, 17 April 2003 at 7:27 PM
I think the last render is awesome! Only the eyes need work, a reflection map or some kind of specularity change. To get rid of the plastic-like look to it. I read an awesome article in 3DArtist a while back about lighting and people, perhaps you can find it online... Still, the article talked about making two tiny spotlights, and smack them RIGHT in front of the eyes, tracking to the eyes objects. Screw with them a bit, and you'll get a cool effect. Another thing, are you using and rear lights? They can add to realism as well... Just some ideas!
AgentSmith ( ) posted Fri, 18 April 2003 at 12:10 AM
Great lighting setups you have there. Nice fading in the back edges. Using the black background makes the figure look softer, more natural overall. I always suggest reading up on real world lighting setups, like in portrait photography. There is a lot there that can be directly applied to 3D. AgentSmith
AgentSmith ( ) posted Fri, 18 April 2003 at 12:15 AM
I like global illumination/True Ambience, but even that needs to be used in small levels. (imho) AS
PJF ( ) posted Fri, 18 April 2003 at 7:10 AM
AgentSmith, can you please explain the lighting system/arrangement you used in your pic above. If it's pure True Ambience, I'd love to know how you got round the issue of mesh non-smoothing. Being able to use imported meshes (especially Poser ones) with True Ambience would be a cheering proposition. Other than the texture map looking a bit too saturated (ouch, sunburn!) I think the figure looks realistically lit.
AgentSmith ( ) posted Fri, 18 April 2003 at 7:55 AM
Yeah, the sunburn texture is intentional, lol. That's how the texture comes anyways. No true ambience used, just a dome array (around 40-50 radial lights), ambient color of the shadows at 33, soft shadows turned on at 25%. (the soft shadows aren't truly needed) I keep the radial lights turned way down, around 5 or less, and I color the lights very, very slightly yellow, and as I duplicate my radial lights into the dome, I will slightly alternate the level of that yellow. I start at R=255,G=255,B=235. I then make some of the blues = 230,235,240, or 245, etc. That's all. But I have a question...(below) AgentSmith
AgentSmith ( ) posted Fri, 18 April 2003 at 7:59 AM
What do you mean by; "how you got round the issue of mesh non-smoothing"? I've used poser figures with True Ambience before, and they look no different at all, as far as smoothing of the mesh goes. Which you shouldn't have to do, by the way at all, if you are exporting out of Poser as a .obj. (Which I suggest you do pretty much always) AS
Aldaron ( ) posted Fri, 18 April 2003 at 11:54 AM
He means that if a poser model is lit with just true ambience (no other light source) then even with 180 smoothing you still have facets as above.
AgentSmith ( ) posted Fri, 18 April 2003 at 9:03 PM
Hmm..what Poser figure version are you using? P4 male, or is it an earlier model? I may be wrong, but it looks as if it is just a lower res figure, meaning less polygons, so more facets. The figure I used above is just the P4 female, but is I were to take the camera closer you would start seeing the facets more clearly. You can see a few already at the top of the head, and the bottom of the breasts. But, I'll do a close-up render of her hand, with true ambience on, to see if there is any big change. AgentSmith
AgentSmith ( ) posted Fri, 18 April 2003 at 9:06 PM
Attached Link: http://www.computerarts.co.uk/magazine/latest.asp?id=32742
By the way, Computer Arts Magazine Issue #38has included on it's CD is the Victoria 1.0 model for free. She carries a fair amount of poly's. AS
Aldaron ( ) posted Fri, 18 April 2003 at 9:13 PM
Yes it was the P4 male. The same render but with normal lightning produced a smooth render.
AgentSmith ( ) posted Fri, 18 April 2003 at 9:16 PM
Strange. And, you're exporting out of Poser as an .obj? AS
AgentSmith ( ) posted Fri, 18 April 2003 at 9:22 PM
The P4 fem hand looks fairly good close-up with true ambience. I'll check out the P4 male... AS
AgentSmith ( ) posted Fri, 18 April 2003 at 9:37 PM
Well, that IS about right for the P4 male polygon-wise. I tried it with true ambience on and off and it looks about the same for me. Of course, what helps hide facets are dark backgrounds. Only way to change this is purchase a higher-res model. (Mike 1.0, 2.0) Or (what I do), post-work the facets away. Sorry. :o/ AS
AgentSmith ( ) posted Fri, 18 April 2003 at 9:39 PM
What's strange is, Bryce says the P4 Female has 30,074 polys, and the P4 Male has 33,234 polys. Obviously, his extra 3,160 polys aren't in his hands... AS
Aldaron ( ) posted Sat, 19 April 2003 at 12:03 AM
Hires textures may help too. I only used the default P4 textures.
FWTempest ( ) posted Sat, 19 April 2003 at 12:03 AM
TheBryster ( ) posted Sat, 19 April 2003 at 6:49 AM
AS: Maybe the MALE has more bits than the female?
AgentSmith ( ) posted Sat, 19 April 2003 at 7:01 AM
That thought occured to me, but I had neutered him before I brought him into Bryce...;o) AS
TheBryster ( ) posted Sat, 19 April 2003 at 7:03 AM
Ouch!
