Thu, Jan 30, 7:33 PM CST
Forum Moderators: Staff
Subject: keeping clothing on in poser5
ishroom ( ) posted Fri, 18 April 2003 at 12:34 AM · edited Thu, 30 January 2025 at 3:44 PM
How do I keep clothing and props on when figure is in a new pose?Poser 5 Reference Manual thinks I allready know how to run a poser program,it's like trying to find out what time it is only to be told how to build a watch but know time !
Ericroy ( ) posted Fri, 18 April 2003 at 9:14 AM
Ishroom, If it is conformable clothing: 1. Select the clothing. 2. On the menu bar, select Figure > Conform to. 3. Pick the figure in the drop down list and click OK. 4. The clothing should snap into place on the figure. After you conform the clothing, you must be careful when posing the figure. If you try to move a figure part, but grab the clothing by mistake, things will distort. I find it easier to pose and animate the figures and then add the clothing last. If the clothing is a prop: 1. Position the clothing exactly the way you want it on the figure. 2. On the menu bar, select Figure > Properties. 3. On the Properties pallet, click on the Properties tab. 4. Click on the Set Parent button. 5. Select the body part that you want the clothing to be attacted to from the list. For example, if the clothing item is a hat, select the figure head. Many clothing props are called smart props. Smart props are already parented, so they snap into position on the body part when you add them to your scene. I hope this helps, Ericroy
ishroom ( ) posted Fri, 18 April 2003 at 9:48 AM
Thank's for the help.
