Carrara F.A.Q (Last Updated: 2025 Jan 04 8:20 pm)
It works for me, so I must not understand what the problem is. If you try a circle array, and use the default settings, it won't look like anything has happened, cause the diameter is too small. Try increasing it by about 3 times. Anyway, like I said, it works for me, so anything I can do to help, i'll do! Hoborg
Hi Chris, Sorry that it took me so long to get back to you. I'm having the same prob. I know that your original post about this indicated that you were trying to make some bricks for a well. I'd create the bricks in the spline modeler positioned in a circle already and extrude them. Hoborg, you say you can create the circle replication with no problem? Could you post a screen capture of the your settings? (Sorry, I'm one of those 'show me a picture' types) Mark
I use the Win NT4 version of Carrara. I am trying to replicate in a circle using the Replicate command in the Edit menu of the Vertex Model Room. I am using an Inserted Block to test with, but nothing happens when I complete the command. What is the secret to making this command work? If anyone knows the correct settings (Arc Angle, Radius, Axis, Rotate Copies, etc.), please respond. Thank You....
