Mon, Dec 2, 3:21 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 02 2:40 am)
Subject: Crosstalk Null Thing
Terry Mitchell ( ) posted Tue, 11 March 2003 at 8:09 PM ยท edited Sat, 30 November 2024 at 3:14 AM
I forgot the tip(s) on how to get two similar characters with different morphs/mats to appear as two distinct characters instead of one mergerd mutant. (I'm trying to get a male and a female version of RDNA's Sluggians in the same scene.) Thanks.
Intel Core I7 3090K 4.5 GhZ (overclocked) 12-meg cache CPU, 32 Gig DDR3 memory, GeoForce GTX680 2gig 256 Bit PCI Express 3.0 graphic card, 3 Western Difgital 7200 rpm 1 Tb SATA Hard Drives
saur ( ) posted Tue, 11 March 2003 at 10:19 PM
Tashar59 ( ) posted Tue, 11 March 2003 at 11:02 PM
Start new scene. Load null first, then figure you want. Load null after each new figure for multiple use. You don't need to load after last figure. Tashar 59
Terry Mitchell ( ) posted Wed, 12 March 2003 at 7:03 AM
That's my problem, I forgot what or where the "null" item is.
ladynimue ( ) posted Wed, 12 March 2003 at 10:32 AM
Attached Link: http://www.daz3d.com/pages/faq/techtipsmain.html
this link might help and open the following link: Cross-talk: What it is... and how to maintain control! Hope this helps ladynimue
igohigh ( ) posted Wed, 12 March 2003 at 1:05 PM
Bloodsong has an all-purpose NULL loader and.....I forget his name (right side of the brain) has the Mil NULL loader. His link can be found at the DAZ FAQ link above.
Terry Mitchell ( ) posted Wed, 12 March 2003 at 5:32 PM
Thank you all. I think I got it under control.
zvzulndr ( ) posted Fri, 18 April 2003 at 3:17 PM
Help! I loaded Rob's Null and followed the instructions to a tee, but I still get crosstalk: This is on Poser 4 (non-propack), with V2 and M2. Does his Null work with V2 and M2 or only the millenium figures? Do you have to load the scene with a null from startup (prefered state) or can you delete the figure so there is "No Figure", load a null and then proceed? Also, Rob mentions something about preparing the .CR2 files which I didn't fully understand. Help!
Tashar59 ( ) posted Fri, 18 April 2003 at 4:44 PM
You need to start a new scene. Then use Null as your first figure, then load vic/mike, then Null, then your next figure and so on. I don't think it works with a previous scene. You may have to close Poser and start from new. Just remember to use Null first.
zvzulndr ( ) posted Fri, 18 April 2003 at 5:30 PM
Thanks! I just figured it out and now it works fine.
