Phil, you are SO helpful! lol mickey, this happens when clothing without a hip is loaded into Tailor and then saved out again. The classical trick is as follows: Open Morph Manager 4 (or other morph transfer app) and load the new version of your stockings. Then load a clean unedited version of the stockings beside. Transfer the new morphs in your non-functioning cr2 to the clean cr2. Save it with a NEW NAME and load in Poser. Should work fine. The actual morphs themselves were OK, it's the carrier cr2 that got garbled in Tailor. What happens in Tailor is due to a bug that causes Tailor to add irrelevant info to the cr2 if it has no hip part. Your alternative method is to open the cr2 in a text editor and clean it, but that requires a steady hand... :o) :] Fish
Hi, I just got Tailor and used the Wizard to fit Billy T's stocking (L) to a V2 model with the Pearfigure morph used on V2. I think every thing went well in Tailor but when I tried to conform the stocking to the V2 model , they went to the head area and won't move down to the leg. Help!!!!
