Carrara F.A.Q (Last Updated: 2024 Nov 05 6:06 am)
Hi Mark, thank you for your answer. Unfortunately I have to animate the continent-outlines in Flash (morphing to text). Therefore the .gif-animation wont help me. Tracing frame by frame is too much work, so I must do it with Cinema 4D and its wrapping function. I just had the hope that it was only my fault and Carrara could do it. Thanks again Knut
Attached Link: http://www.hcstudios.com/carrara/continents.zip
I found this freeware globe a while back.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Can I "map" splines on a sphere? To use the flash plugin I need a globe which continent-outlines are made of splines. A bitmap texture does not help me because I need the outlines to be flash objects. The 2D-outlines are made with illustrator. I was only able to make them cylindrical by using the carrara modifier "Biegen und Verdrehen" (sorry, i am german)but I cannot get a real sphere. Could you please help me?
