Wed, Feb 26, 8:33 AM CST
Subject: Can anyone get this .mat to work?
Quikp51 ( ) posted Fri, 02 June 2000 at 3:13 AM · edited Wed, 26 February 2025 at 4:39 AM
Attached Link: http://www.deeptextures.demon.co.uk/Dtextres/DpTxfrme.htm
Just click on the tractor to get the yellow metal material and try to open it in Bryce4.0. I get an error every time , do you?
Siegbert ( ) posted Fri, 02 June 2000 at 6:44 AM
Hi, I just downloaded the mat. I checked the mat with a hex-editor and saw that the header is defect and also at the bottom some parameters representing the attributes have unusual ascii codes. These are not common in *.mat files. You will have to get in touch with the author, I think Siegbert
Roshigoth ( ) posted Fri, 02 June 2000 at 12:37 PM
Could it be possible it's a Max .mat file? Max uses .mat as an extension for its material libraries too. Rosh
Roshigoth ( ) posted Fri, 02 June 2000 at 12:41 PM
Ok, my bad. I hadn't looked at the page itself. =) Rosh
