Sun, Jan 26, 11:23 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 20 11:31 am)
Carrara Free Stuff here.
Subject: Color in shadows? (Carrara)
jschoen ( ) posted Fri, 02 June 2000 at 2:16 PM · edited Sun, 26 January 2025 at 11:21 AM
I've tried everything I can think of. Does anyone know how to get the color of a transparent object to show up in the shadows? Here is what I'm trying to do. The main pic is Carrara, the inset is Bryce. I do have "Light through transparrency" turned on. James
aeryk71 ( ) posted Fri, 02 June 2000 at 2:54 PM
You have to put the colors into the transparency channel... Unfortunately I have not been able to get it to look as good as bryce does... Mark may have better info for you, Aeryk71
MarkBremmer ( ) posted Fri, 02 June 2000 at 4:46 PM
cool1.jpg Hi James, The problem is that Carrara, Soft Shadows and Transparency don't get along. If you disable the Soft Shadows (use Raytraced), the color of the object will color the shadow too. Here's a work-around for your situation though. It's not perfect for all circumstances but works great here: Leave your scene as it is. Change the light to Raytraced shadows. Select the ground plane and go to the Effects portion of the object tray. Enable blur and adjust to your liking. (On my system, if I adjust the blur and close the window before the tiny rendering in the blur window completly draws I crash. However, if it draws there are no problems.) Hope that this helps! Mark
jschoen ( ) posted Fri, 02 June 2000 at 11:19 PM
jnjshadow.jpg Well I came up with a longer render solution. I hope the next upgrade will fix this little problem. Thanks all BTW, for your input. James
